Kotlin example for AndroidSDK to LogIn to ParticleCloud
This is example Kotlin code for AndroidSDK to LogIn to the ParticleCloud. This assumes you have set up your build.gradle files in AndroidStudio for the correct libraries and have a LoginActivity with EditText email and password widgets and login_button widget. The heavy lifting in this example comes from Anko and Kotlinx coroutines. This hands off to a ValueActivity where you could get your ParticleDevice list and display info, see events, log off, etc. I hope to have a complete app example on GitHub in the future. Remember: the debug console in AndroidStudio and the use of Log.e(), Log.i() and e.printStackTrace() are your friends! I hope this saves you some time . . .
package com.YourCompany.particlemonitor
import android.os.Bundle
import android.support.v7.app.AppCompatActivity
import android.util.Log
import io.particle.android.sdk.cloud.ParticleCloudSDK
import io.particle.android.sdk.cloud.exceptions.ParticleCloudException
import kotlinx.android.synthetic.main.activity_login.*
import kotlinx.coroutines.GlobalScope
import kotlinx.coroutines.async
import kotlinx.coroutines.runBlocking
import org.jetbrains.anko.longToast
import org.jetbrains.anko.startActivity
class LoginActivity : AppCompatActivity() {
    override fun onCreate(savedInstanceState: Bundle?) {
        super.onCreate(savedInstanceState)
        setContentView(R.layout.activity_login)
        ParticleCloudSDK.init(this)
        // Pre-populate with text for testing
        email.setText ("MyEmail@gmail.com")
        password.setText("MyPassWord")
        login_button.setOnClickListener { startLogin() }  // Bind login_button handler
     // called from login button
    // Kotlin Coroutines version
    fun startLogin() {
        val myEmail: String = email.text.toString()    // Not correct if just email.text
        val myPassword: String = password.text.toString()
         runBlocking {  // Encapsulate in Main (UI) thread
             // Deferred Boolean to assess logIn success
             var loginSuccess = GlobalScope.async {
              // launch new coroutine in background  and continue (Non-Blocking)
                 try {
                     ParticleCloudSDK.getCloud().logIn(myEmail, myPassword)
                     Log.i("ParticleCloud", "Successful logIN!")
                     true
                 } catch (e: ParticleCloudException) {
                     Log.e("ParticleCloud", e.bestMessage)
                     // Don't use any Toast() in WorkerThread, it will crash
                     e.printStackTrace()
                     false
             if (loginSuccess.await()) {  // Wait for deferred var, continue if logged in
                 longToast("Logged In!")
                 // Anko version  Hand off to next activity with status
                 startActivity<ValueActivity>("LoggedIn" to "Yes!")
             } else longToast("WRONG! Try again . . .")
Also, this would be an example of handler code for your logOutButton in your ValueActivity:
fun logOut() {  // Not a WorkerThread, does not need Async!
        ParticleCloudSDK.getCloud().logOut()
        Log.i("ParticleCloud", "Logging out . . .")
        longToast("Logging Out!")
        startActivity<LoginActivity>("LoggedIn" to "No")
@CaptIgmu
We’re you able to create a complete example app using Kotlin? If not, can you share your build.gradle file?
I thought I had all the dependencies for Kotiln but I can’t seem to get you sample code working. Thanks!
