Known issue: long delays or blocking code kills the connection to the Cloud
Hey all,
There are a number of threads relating to the same general issue, which is that the Core becomes unresponsive after flashing your own code, and needs to be factory reset to get it back in action. I wanted to start a new thread to explain the issue, how to avoid it in the short term, and what we’re doing in the long term to fix it.
So here’s the rub:
  • If you write code that blocks for a significant period of time (more than a couple of seconds), it may block communications with the Cloud. This means that an over-the-air firmware update can’t be run, because the Core isn’t receiving messages from the Cloud.
  • Blocking code includes delay() and opening a TCP socket using TCPClient, because the CC3000’s connect() function blocks for up to 60 seconds when it fails to connect.
  • There is a fix in the works, which involves decoupling the Spark firmware and the user application so they don’t block each other. This is top priority for us, but it’s going to take some time. We’ll let you know when the fix is available, and it will be distributed with new firmware that you flash from the web IDE.
  • In the meantime, try to avoid long delays if you can, or break them up so that your loop() doesn’t take more than a couple of seconds to run. In the case of TCP, if your socket opens successfully, it should work fine.
  • If you do encounter this issue, a factory reset should always solve the problem, or you can do your development locally and program the Core over USB.
Questions or comments? Reply to this thread!
Glad to see this is on the list to be fixed. Sounds like Spark is hooking in the cloud functionality between runs through loop()??? When making mistakes in code its is trivial to block within the loop by accident which means factory reset… Is there a key combo to reflash tinker but not clear the WiFi setup? that is the biggest pain for me right now.
Almost any delay seems to trigger a crash.
I ran this uptime test to test out the random crashing.
int UpTime = 0;
Spark.variable("UpTime", &UpTime, INT);
long minutes = (millis() / 1000)  / 60;
long seconds = (millis() / 1000) % 60;
UpTime = int(minutes);
Serial.print(minutes);
Serial.print(":");
Serial.println(seconds);
delay(1000);
And it will crash every time. nothing consistent though, could run for a few minutes, could run for half an hour but it constantly crashes.
But perhaps this is a different issues as it’s not related to programming only to running the application and a simple reset button get’s the core running again.
@mrOmatic this might be a real crash due to your code. Try making your minutes and seconds variables float or double rather than long.
Hello all.
I got my cores a few days ago and started programming them. I too saw the consistent crashes. Eventually I noticed that it was crashing during a call to client.println, and perhaps Serial.println too.
Since what is being done in the example code above is nearly identical to what I was doing I thought I would share my “fix” - Don’t use println :slight_smile:
I format the string I wish to print, then use .write with a byte count.
For example, you could change the print calls above to something like this:
char io[80]; // I put this up before setup() to create a global scope character buffer
sprintf(io, “%d:%d\n”, (int)minutes, (int)seconds);
Serial.write((const uint8_t *)io, strlen(io));
Before I did this my Core was crashing every minute or two. After this change it has been running for nearly four hours.
@zach: If the crashes would actually relate to the use of long instead of a floating point number type it would still be a bug, since the outlined code is perfectly acceptable in C - and even more in C++ what your preprocessor seems to produce out of the user code (especially since all involved types are int types - even the constants 60 & 1000 - not 60.0 & 1000.0)
Fair enough, although it looks like the issue might actually be a bug in our implementation of Serial.println(). @mrOmatic are you able to get it working with @pilottrack’s fix?
I’m back from a few days of holidays, friends family etc
OK i’m testing the print thing now by removing the serial print completely and monitoring via the cloud, it doesn’t match with what I’ve observed but happy to test it out.
I’ve been meaning on posting my observation of the core crashing.
When I was doing the uptime testing I was monitoring via serial and via a script looking at the cloud service, additionally the cloud monitoring script would notify me via Pushover https://pushover.net/ when the could returned a 408 status (Request timeout).
What I found it the cloud side would crash first, I’d get a couple of notifications of 408 status (monitoring every 10 seconds.) I’d go back to my desk and the Spark LED would still be breathing and the serial monitor still happy scrolling down. Then in a few seconds the serial monitor would halt and the LED would switch to flashing.
So it always seemed that the Cloud side would fail first and then the user application would crash second.
I’s just an observation, hope it might be useful.
So just for kicks I had another play with testing uptime when using a 1 second delay.
I striped out all the print comments and just used this…
int UpTime = 0;
  UpTime = int((millis() / 1000)  / 60);
  delay(1000);
So it still consistently crashes still at fairly random intervals, interestingly enough the average for 10 runs on this code was down to 9.9 minutes where the previous version had a 10 run average of 17.2 minutes.
So that’s enough of that, it looks like delay’s crash cores, especially when my other core has been running far more complex code doing TCP, MQTT, debouncing button’s etc for day’s without crashing.
So for clarification the test’s I’ve been doing relate to the ‘Cyan flash of death’ and not apparently the other could connection problem from the original post.
A fix has been implemented, but not yet merged into master. Check out this feature branch:
You’ll need to get the context-switching branches of all 3 firmware repositories and build locally, following instructions on the README. This will be pushed to the web IDE when it’s been fully vetted.
This feature is still in testing, and leaves very little RAM for the user, which is something we’re working on. However if you’re all about the bleeding edge, check it out!
Subscribing to this thread so I can hear about when this patch makes it to the IDE!
It sure was glorious to see my output flying into my console one time though. The nice thing is I know my loop is still running fine since I hooked up an LED that changes it’s brightness based on the analog pin’s output.
Even after a factory reset I haven’t been able to see that output again :frowning:
And here is the code that I’m using on my core:
int LED = D1;
int TILT = A0;
int val = 0;
TCPServer server = TCPServer(4444);
TCPClient client;
    Serial.begin(9600); //adding or removing this makes no difference
    pinMode(LED, OUTPUT);
    server.begin();
    //get the current value of the tilt sensor
    val = analogRead(TILT);
    //use the debug LED to show things are still working
    analogWrite(LED, val/16);
    //if any clients are connected, fire them some data
    client = server.available();
    if(client) {
        server.println(val);
    //fast fast!
    delay(10);
@Endoplasmic, what was your last commit status after “context-switching” pull.
The recent increase of WLAN SPI baud rate settings didn’t work well with context-switching so had to revert that back to older settings.
Since this branch and dependent branches are under continuous development and testing, not all commits would work as per expectation.
The last known stable build commits(core-firmware and core-common-lib) is this:
Older stable commits:
@Endoplasmic,
Getting the TCP and other Network related libraries to work under context-switching branch is Work in progress. Presently those libraries don’t work and will lead to HardFault exceptions.
Oh I didn’t pull it down at all. Wanted to wait for the smoke to clear, which sadly means for now, dust to gather on the Spark :frowning:
Wanted to bump this up. Using serial -> USB has been fine for a while, but I want to be able to have my core connected somewhere else that isn’t the server (or to a computer at all).
Just curious if the TCPServer stuff is getting the love it needs is all :smile:
Hi, can anyone tell me if this is still an issue with the latest firmware, or has it been addressed?
Thanks.
HI @Raldus
The current firmware version allows you to call delay() with a large number and still have the cloud work. If the delay value you give is larger than 1 second (1000 ms value) then the Spark cloud handling code is called, otherwise it is not.
The cloud handling code is always called when you reach the end of loop() and go round again.
You could still break the cloud connection by having lots and lots of little delays that add up to a big delay without going around the loop, but that is pretty unlikely.
Hi @bko @Raldus, the case where “lots and lots of little delays that add up to a big delay” is also handled well in the delay() logic so should not be a problem. The if ((elapsed_millis >= spark_loop_elapsed_millis) || (spark_loop_total_millis >= SPARK_LOOP_DELAY_MILLIS)){} handles both conditions: single long delays as well as many short delays adding to long delays.
Ah, sadly, I have one of these indoor temp/humidity sensors (I’m just playing around with it), and the data read time (lots and lots of microsecond-level delays) is on the order of 2 seconds (to be safe, I’d probably want to assume that a call to loop() could take as long as 4-5 seconds). The cheesy approach to reading data would use busy loops, but it sounds like calling delayMicroseconds() would not help here.
Maybe I’ll connect this up to a raspberry pi, instead.
