Hello! I have been working on an Arduino project, and recently ported the code to my Spark Core. I understand that when the core powers up, it connects to the cloud (which is a blocking function). The problem I have is not depending so strongly on a wifi connection. For example, if my router goes down while the core is doing an important task, it needs to be able to work without the wifi and worry about connecting later.
I’ve read about the new SYSTEM_MODE(SEMI_AUTOMATIC);
and believe that control over Spark.connect() will help me. But, I’ve noticed that the connecting function will not stop until it has found a connection. Is there any way to try to find a connection, but only for a set period of time? Then, if the cloud connection is lost my code can enter a special mode where it saves data to upload later, etc. while only periodically checking for a cloud connection.
@JDvorak yes, you can totally do that. I had the same requirement. I booted in SYSTEM_MODE(SEMI_AUTOMATIC) and start my program offline.
Then in my loop() I check to see if connected. If not connected, I run a try to connect routine. This routine starts a timer based interrupt using “SparkIntervalTimer”, then calls Spark.connect(). Once connected, I disable the timer based interrupt. However, if unable to connect, eventually the timer based interrupt gets triggered and the ISR includes a call to Spark.disconnect().
It seems like this should either be documented under Spark.connect() or built into the API… I’m sure lots of people need this functionality for projects / products.
@rocksetta, that line IS for the Spark Core!! The entire library was adapted for the Core. What the line you highlighted shows is a direct GPIO pin manipulation which is much faster than digitalWrite(). If you need any help with the library, let me know
I will try to write one, but I spend so much time re-flashing dead cores that it would be nice if someone who knows what they are doing would write a basic “Hello World No Wifi” for the situation in which, if you are away from wifi and you want your Spark Core to just work (as if in manual mode). Then if you are near your wifi, when you power on it gives you 30 seconds to reflash the core to update your program.
My hack works fine for me since I carry my cell with a hotspot but not much use to others in the same situation.
// must have wifi working for startup, since automatic mode blocks until wifi is connected
// Can use cell phone hotspot as long as it is setup earlier with another cell phone.
delay(2000); //give some time to reflash the core
delay(2000);
delay(2000);
delay(2000);
delay(2000);
delay(2000);
delay(2000);
delay(2000);
delay(2000);
delay(2000);
Spark.disconnect(); // basically puts you in manual mode, so should ignore any poor wifi reception issues
@rocksetta, I am going to take this up with other Elites and the Spark Team. With both WiFi.listen() and Spark.connect() blocking user code, having an “out” for the Core would be good. This, of course, will not be a problem on the Photon
Great idea. Here is my suggestion, but I have to get home to try it out. At least it compiles (assuming you include the two sparkIntervalTimer files .h and .cpp)
#include "SparkIntervalTimer.h"
// Create IntervalTimer object
IntervalTimer myTimer;
// Pre-define ISR callback functions
void checkWifi(void);
//const uint8_t ledPin = D7; // LED for first Interval Timer
void setup(void) {
pinMode(D7, OUTPUT);
digitalWrite(D7,HIGH); // blink D7 fast once before timer activated
delay(40);
digitalWrite(D7,LOW);
myTimer.begin(checkWifi, 60000, uSec); // check for wifi every 60 seconds or until stopped
digitalWrite(D7,HIGH); // blink D7 slow twice when timer activated (checks if blocking)
delay(500);
delay(500);
delay(500);
//volatile unsigned long blinkCount = 0; // use volatile for shared variables seems cool to know
void checkWifi(void) {
Spark.connect(); // this is normally a blocking function
int myLoop;
int myConnect = 0; // 0 just starting, 1 connected, 2 manual mode
if (myConnect == 0) { // check for connectivity
if (WiFi.ready()){ // wifi is connected
myTimer.end(); // shut down the timer
myConnect = 1; // says wifi connected
} else {
myLoop++;
delay(1000);
if (myLoop >= 20) { // tried to get Wifi for 20 seconds
Spark.disconnect(); // not sure if this is needed
myTimer.end();
myConnect = 2; // says no wifi
if (myConnect == 1) { // do your wifi connected loop
digitalWrite(D7,HIGH); // blink D7 fast to show that Wifi is working
delay(100);
delay(100);
// other statements here
if (myConnect == 2) { // do your manual loop
digitalWrite(D7,HIGH); // leave D7 on to show manual mode
if (myConnect >= 1) { // do statements that are for either manual or automatic mode
I'd guess it won't actually do what you intend, since you should not call a blocking function inside an ISR
In the other thread I wrote (and am still convinced, to be true)
So you'd rather call Spark.connect() in your normal code but "cancel" the connection attempt from your ISR by calling Spark.disconnect() (and possibly WiFi.off() aswell).
Ok, so here is the second attempt, using the timer to shutdown the connect process. It compiles but I have not tested it. Also finally learnt how to use the spark libraries. So the include statement is a bit easier. Can someone else load this as I have my spark core testing my Pixy Camera Rover and I don’t want to break it again.
Of course Spark.io could always send me a few Cores (like a class set=15 one per two students), so I can continue trying to make Spark products easier to use
#include "SparkIntervalTimer/SparkIntervalTimer.h"
// Attempt number 2
// check Spark Core for Wifi on startup, if no wifi then allow it to run none-cloud dependent activities.
void setup(void) {
delay(40);
myTimer.begin(checkWifi, 20000, uSec); // check for wifi and shutdown if no connection after 20 seconds
delay(50);
Spark.connect(); // try to connect
delay(500);
delay(500);
delay(500);
volatile unsigned long myConnect = 0; // use volatile for shared variables: 0 just starting, 1 connected, 2 no connectivity, 99 first timer done
if (myConnect != 0){ // not the first activation of the timer
if (WiFi.ready()){ // this loop should wait 20 seconds to occur
myConnect = 1; // means wifi got connected
} else {
Spark.disconnect();
WiFi.off();
myConnect =2; // means no wifi
myTimer.end(); // no mater what happens shut down the timer since we only want it to work once
} else {
myConnect = 99; // identifies the first run has completed.
int myLoop;
delay(100);
delay(100);
if (myConnect == 2) { // do your no wifi loop
if (myConnect == 1 || myConnect == 2) { // do statements that are for either wifi or no wifi modes
Here is information about the Pixy Camera Rover, it follows a certain color. I still have to tweak some values so the rover doesn’t go racing down the street.
After the amout of effort you already put into this, I’d like to suggest these adaptions
At this point I haven’t tested them myself, but just from experience this should work - and I’ll test it soon and correct if required Edit: This is now working code, but in my tests I’ve got the impression, all that interrupt/timer effort isnotneeded anyhow, since Spark.connect() doesn’t seem to block anymore (despite still being stated to be and as I remember it to have been) @mdma, has anything been changed “recently” that hasn’t found its way into the docs? Or am I imagining things?
volatile uint8_t isrTriggered = 0;
const unsigned long CONNECT_TIMEOUT = 30000;
unsigned long lastMillis; // it's always good to have this for non-blocking delays
void setup(void) {
delay(40);
// this would only wait 20ms since uSec is micro seconds
// myTimer.begin(checkWifi, 20000, uSec); // check for wifi and shutdown if no connection after 20 seconds
// the other time scale is half-milliseconds (hence 2*)
myTimer.begin(checkWifi, 2 * CONNECT_TIMEOUT, hmSec);
lastMillis = millis(); // store soft-delay reference time
// try to connect
isrTriggered = 0;
Spark.connect();
if (!isrTriggered)
{ // only wait if connection attempt succeeded
myTimer.end(); // don't disconnect prematurely
while ((millis() - lastMillis) < CONNECT_TIMEOUT)
digitalWrite(D7, HIGH);
delay(50); // flash LED about 10Hz
Spark.process();
digitalWrite(D7, LOW);
Spark.disconnect(); // missed your chance for OTA flashing
WiFi.off(); // deactivate WiFi in any case
// no need to re-check inside loop() now
delay(500); // flash LED about 10Hz
isrTriggered = 1;
Spark.disconnect(); // no more required inside ISR
Edit: Fixed some build error - Spark.connect() does not return any success/fail indicatior
Yep, that’s the one that introduced SYSTEM_MODE().
Only after this it became even possible to squeeze in some code before Spark.connect() that might be able to stop any running connection attempt.
Nothing has changed since the last release in October 2014. Afaict, Spark.connect() will never block, since it just calls WiFi.connect(), which is non-blocking, and sets a flag to cause the background thread to connect to the cloud.
When the user calls Spark.connect(), the user code will be blocked, and the Core will attempt to negotiate a connection. This connection will block until either the Core connects to the Cloud or an interrupt is fired that calls Spark.disconnect().
@ScruffR, @mdma perhaps some test code is in order to establish if Spark.connect() or WiFi.connect() actually block user code or not. The story until now has been that user code will block when the cloud connection is LOST in AUTOMATIC mode but SEMI_AUTOMATIC and MANUAL mode scenarios are not so clear. It would be good to understand the behavior once and for all
