Issues compiling in the cloud?
Is anyone having timeouts while compiling on the cloud using either the build web app or the ATOM IDE?
same for me, it happened last night, fixed. but now happened again.
I am also having issues compiling.
I am thinking to setup up my own compiler in the local environment with local server, anyone knows how to do it
I think the issue is fixed. Can you all try now?
Since last night (23:00 Aug 22nd, BST),
I have been having problems compiling.
Particle Build and Particle Dev are failing silently, while when compiling from command line I receive this error:
caprazzo:Contorto_particle/ $ particle compile photon water_sensor_tuning.ino [8:52:47]
Compiling code for photon
Including:
pushing file: water_sensor_tuning.ino
Token error: { [Error: socket hang up] code: ‘ECONNRESET’ }
compile got error: { [Error: socket hang up] code: ‘ECONNRESET’ }
Compile failed. Exiting.
Any help is appreciated.
-teo
I too has some problem compiling yesterday and today, I thinks now it is fixed. For me it is compiling now.
@caprazzo: There was a topic about exactly this. Please check before opening a new thread.
This way your personal issue can be seen in the bigger picture and can be answered once, rather than some scattered threads not getting answered at all.
Plus there is another one here, where “officials” are involved already
The server has failed to process the request on time. Please try again
All appears to be back online again…
Good!
Hi All,
Sorry about that! Over the weekend the build farm got a little behind the demand. We amped up the workers, and we’re hoping to deploy even more resources to the build farm in the near future.
David
