I am not able to compile locally anymore, I was working just fine yesterday and today, I keep getting this Could not find task error. I have tried this on the project I compiled yesterday and created a new one, both are doing the same thing. I have disabled all extensions, no luck, reinstalled workbench, no luck.
"username": "rminorgood@gmail.com",
"workspace": {
"name": "testproject",
"isWorkspace": false,
"folders": []
"cli": {
"binpath": "/home/good/bin/particle",
"ok": true,
"version": "3.30.0"
"localCompiler": {
"ok": false,
"dependencies": [
"id": "deviceOS@6.1.1",
"ok": true
"id": "gcc-arm@10.2.1",
"ok": false
"id": "buildtools@1.1.1",
"ok": true
"id": "buildscripts@1.16.0",
"ok": true
"id": "openocd@0.12.0-particle.2",
"ok": true
"platform": {
"os": "linux",
"type": "Linux",
"release": "6.8.0-50-generic",
"arch": "x64",
"path": {
"key": "PATH",
"value": "/home/good/bin:/home/good/bin:/home/good/.local/bin:/home/good/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/good/.local/bin",
"entries": [
"/home/good/bin",
"/home/good/bin",
"/home/good/.local/bin",
"/home/good/bin",
"/usr/local/sbin",
"/usr/local/bin",
"/usr/sbin",
"/usr/bin",
"/sbin",
"/bin",
"/usr/games",
"/usr/local/games",
"/snap/bin",
"homeDir": "/home/good",
"particleDir": "/home/good/.particle",
"particleToolchainDir": "/home/good/.particle/toolchains"
"env": {
"CHROME_DESKTOP": "code.desktop",
"CINNAMON_VERSION": "6.2.9",
"CLUTTER_IM_MODULE": "ibus",
"DBUS_SESSION_BUS_ADDRESS": "unix:path=/run/user/1000/bus",
"DESKTOP_SESSION": "cinnamon",
"DISPLAY": ":0",
"GDK_BACKEND": "x11",
"GDMSESSION": "cinnamon",
"GDM_LANG": "en_US",
"GIO_LAUNCHED_DESKTOP_FILE": "/usr/share/applications/code.desktop",
"GIO_LAUNCHED_DESKTOP_FILE_PID": "47162",
"GJS_DEBUG_OUTPUT": "stderr",
"GJS_DEBUG_TOPICS": "JS ERROR;JS LOG",
"GNOME_DESKTOP_SESSION_ID": "this-is-deprecated",
"GPG_AGENT_INFO": "/run/user/1000/gnupg/S.gpg-agent:0:1",
"GTK3_MODULES": "xapp-gtk3-module",
"GTK_IM_MODULE": "ibus",
"GTK_MODULES": "gail:atk-bridge",
"HOME": "/home/good",
"LANG": "en_US.UTF-8",
"LANGUAGE": "en_US",
"LIBVIRT_DEFAULT_URI": "qemu:///system",
"LOGNAME": "good",
"ORIGINAL_XDG_CURRENT_DESKTOP": "X-Cinnamon",
"PATH": "/home/good/bin:/home/good/bin:/home/good/.local/bin:/home/good/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/good/.local/bin",
"PWD": "/home/good",
"QT_ACCESSIBILITY": "1",
"QT_IM_MODULE": "ibus",
"SESSION_MANAGER": "local/good-B550-AORUS-PRO:@/tmp/.ICE-unix/1957,unix/good-B550-AORUS-PRO:/tmp/.ICE-unix/1957",
"SHELL": "/bin/bash",
"SHLVL": "0",
"SSH_AUTH_SOCK": "/run/user/1000/keyring/ssh",
"USER": "good",
"VSCODE_CODE_CACHE_PATH": "/home/good/.config/Code/CachedData/138f619c86f1199955d53b4166bef66ef252935c",
"VSCODE_CRASH_REPORTER_PROCESS_TYPE": "extensionHost",
"VSCODE_CWD": "/home/good",
"VSCODE_ESM_ENTRYPOINT": "vs/workbench/api/node/extensionHostProcess",
"VSCODE_HANDLES_UNCAUGHT_ERRORS": "true",
"VSCODE_IPC_HOOK": "/run/user/1000/vscode-1bacd7f4-1.96-main.sock",
"VSCODE_NLS_CONFIG": "{\"userLocale\":\"en-us\",\"osLocale\":\"en-us\",\"resolvedLanguage\":\"en\",\"defaultMessagesFile\":\"/usr/share/code/resources/app/out/nls.messages.json\",\"locale\":\"en-us\",\"availableLanguages\":{}}",
"VSCODE_PID": "47162",
"XAUTHORITY": "/home/good/.Xauthority",
"XDG_CONFIG_DIRS": "/etc/xdg/xdg-cinnamon:/etc/xdg",
"XDG_CURRENT_DESKTOP": "X-Cinnamon",
"XDG_DATA_DIRS": "/usr/share/cinnamon:/usr/share/gnome:/home/good/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share",
"XDG_GREETER_DATA_DIR": "/var/lib/lightdm-data/good",
"XDG_RUNTIME_DIR": "/run/user/1000",
"XDG_SEAT": "seat0",
"XDG_SEAT_PATH": "/org/freedesktop/DisplayManager/Seat0",
"XDG_SESSION_CLASS": "user",
"XDG_SESSION_DESKTOP": "cinnamon",
"XDG_SESSION_ID": "c2",
"XDG_SESSION_PATH": "/org/freedesktop/DisplayManager/Session0",
"XDG_SESSION_TYPE": "x11",
"XDG_VTNR": "7",
"XMODIFIERS": "@im=ibus",
"_": "/usr/share/code/code",
"ELECTRON_RUN_AS_NODE": "1"
"versions": {
"node": "20.18.1",
"acorn": "8.12.1",
"ada": "2.9.0",
"ares": "1.33.1",
"base64": "0.5.2",
"brotli": "1.0.9",
"cjs_module_lexer": "1.4.1",
"cldr": "44.1",
"icu": "74.2",
"llhttp": "8.1.2",
"modules": "128",
"napi": "9",
"nghttp2": "1.61.0",
"openssl": "0.0.0",
"simdutf": "5.5.0",
"tz": "2024a",
"undici": "6.20.0",
"unicode": "15.1",
"uv": "1.46.0",
"uvwasi": "0.0.21",
"v8": "12.8.374.38-electron.0",
"zlib": "1.3.0.1-motley",
"electron": "32.2.6",
"chrome": "128.0.6613.186",
"microsoft-build": "10629634"
"vscode": {
"appName": "Visual Studio Code",
"appRoot": "/usr/share/code/resources/app",
"machineId": "",
"sessionId": "",
"version": "1.96.0"
"extensions": [
"id": "ms-vscode.js-debug",
"version": "1.96.0"
"id": "ms-vscode.js-debug-companion",
"version": "1.1.3"
"id": "ms-vscode.vscode-js-profile-table",
"version": "1.0.10"
"id": "marus25.cortex-debug",
"version": "1.12.1"
"id": "mcu-debug.debug-tracker-vscode",
"version": "0.0.15"
"id": "mcu-debug.memory-view",
"version": "0.0.25"
"id": "mcu-debug.peripheral-viewer",
"version": "1.4.6"
"id": "mcu-debug.rtos-views",
"version": "0.0.7"
"id": "ms-vscode.cpptools",
"version": "1.22.11"
"id": "particle.particle-vscode-core",
"version": "1.16.32"
"id": "particle.particle-vscode-pack",
"id": "particle.particle-vscode-snippets",
"id": "particle.particle-vscode-theme",
I have no idea what could have changed. Any ideas?
