Supporting information
- VSCode Version:Version 1.27.2 (1.27.2)
- OS Version: macOS 10.13.6
- Other extensions installed:
ode --list-extensions
[createInstance] extensionManagementService depends on downloadService which is NOT registered.
Zignd.html-css-class-completion
cazzar09.Gradle
ecmel.vscode-html-css
HookyQR.beautify
jchannon.csharpextensions
magicstack.MagicPython
marus25.cortex-debug
michelemelluso.code-beautifier
ms-vscode.cpptools
naco-siren.gradle-language
particle.particle-vscode-core
particle.particle-vscode-snippets
particle.particle-vscode-theme
vscjava.vscode-java-debug
vscjava.vscode-java-pack
vscjava.vscode-java-test
vscjava.vscode-maven
I’ve been trying to compile some previously used code but I’m running into a couple of issues with normally pre defined libs 1:
LOW_BYTE HIGH_BYTE etc seem to be undefined. VS Code shows the squiggle and the compile fails. I thought these were part of the standard wiring libs, but I’m not sure.
I’m also trying to compile a BLE sample for the RedBear DUO, which works fine on Particle cloud.
https://raw.githubusercontent.com/redbear/STM32-Arduino/master/arduino/libraries/RedBear_Duo/examples/03.BLE/BLEController/BLEController.ino
I’m getting errors on all the BLE functions and #DEFINES
