VSCode: 1.27.2
The little red lines show up on D6 and under OUTPUT, HIGH, LOW and delay.
But it appears to compile fine.
VSCode: 1.27.2
I’m not seeing that problem. Have you downloaded the local toolchain? Did you let VS Code index your source folder? And did you use “particle: create new project” or open an existing project?
Yes, I downloaded the 3 vsix files and added each and did a reload after each. I then launched a new VSCode window and created a new empty directory to do some testing. I then did Particle: Create new project. I then went to the src directory and found the initial ino file with my project name. I then typed in the basic blink (“hello world”) program. That is where I see these errors.
Uninstalling the workbench extension and reinstalling appears to have fixed the issue. Hooray!
