When i try to compile a simple program on a recently installed Workbench Alpha 7 i receive the following error:
make -C /home/ijbgreen/.particle/toolchains/deviceOS/1.0.0/firmware-1.0.0/modules/photon/user-part/ clean
fatal: not a git repository (or any of the parent directories): .git
make[2]: Entering directory `/home/ijbgreen/.particle/toolchains/deviceOS/1.0.0/firmware-1.0.0/modules/photon/user-part'
../../../build/module.mk:227: warning: overriding recipe for target `/home/ijbgreen/Particle'
../../../build/module.mk:220: warning: ignoring old recipe for target `/home/ijbgreen/Particle'
../../../build/module.mk:227: warning: overriding recipe for target `Workbench/WaterLevel/target//Particle'
../../../build/module.mk:220: warning: ignoring old recipe for target `Workbench/WaterLevel/target//Particle'
../../../build/module.mk:236: warning: overriding recipe for target `/home/ijbgreen/Particle'
../../../build/module.mk:227: warning: ignoring old recipe for target `/home/ijbgreen/Particle'
../../../build/module.mk:236: warning: overriding recipe for target `Workbench/WaterLevel/target//Particle'
../../../build/module.mk:227: warning: ignoring old recipe for target `Workbench/WaterLevel/target//Particle'
../../../build/module.mk:260: warning: overriding recipe for target `/home/ijbgreen/Particle'
../../../build/module.mk:236: warning: ignoring old recipe for target `/home/ijbgreen/Particle'
../../../build/module.mk:259: *** mixed implicit and normal rules. Stop.
make[2]: Leaving directory `/home/ijbgreen/.particle/toolchains/deviceOS/1.0.0/firmware-1.0.0/modules/photon/user-part'
make[1]: *** [/home/ijbgreen/.particle/toolchains/deviceOS/1.0.0/firmware-1.0.0/modules/photon/user-part/makefile]Error 2
make[1]: Leaving directory `/home/ijbgreen/.particle/toolchains/deviceOS/1.0.0/firmware-1.0.0/modules'
make: *** [clean-all] Error 2
The terminal process terminated with exit code: 2
Ambient:
- VSCode Version: 1.30.2
- OS Version: Fedora 29 - 4.20.3-200.fc29.x86_64
- Other extensions installed: None
