I have been running particle workbench on a clean install of VS Code running on a clean install of Ubuntu 18.10. So far everything seems to work great except for the local compile - I have had this same issue on RC5, 6, and 7. I get the following output:
cd "/home/scott/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27//main" && make all
fatal: not a git repository (or any of the parent directories): .git
make[1]: Entering directory `/home/scott/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27/main'
make -C ../modules/argon/user-part all
make[2]: /home/scott/.particle/toolchains/gcc-arm/5.3.1/bin/arm-none-eabi-gcc: Command not found
make[2]: Entering directory `/home/scott/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27/modules/argon/user-part'
/home/scott/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27/build/arm-tools.mk:61: *** "ARMgcc version 5.3.1 or later required, but found ". Stop.
make[2]: Leaving directory `/home/scott/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27/modules/argon/user-part'
make[1]: *** [modules/argon/user-part] Error 2
make[1]: Leaving directory `/home/scott/.particle/toolchains/deviceOS/0.8.0-rc.27/firmware-0.8.0-rc.27/main'
make: *** [compile-user] Error 2
The terminal process terminated with exit code: 2
Not sure about the ARM GCC version… /home/scott/.particle/toolchains/gcc-arm/5.3.1/bin/arm-none-eabi-gcc definitely exists. I also tried installing manually via sudo apt install gcc-arm-none-eabi. As a result arm-none-eabi-gcc -dumpversion now returns 6.3.1 from the terminal but the same issue persists. Any ideas?
