[ISSUE] no source file found for local compile
fresh install of VSCode, no problems installing Particle extensions, local compile toolchain. In time honoured fashion, I'm trying a Hello World program. Created a new Particle project, which compiles via the cloud, but not locally.
The HelloWorld program IS in a Git repository, and I understand the fatal errors relating to git can be ignored: but for some reason the local compiler isn't finding HelloWorld.ino. Any suggestions?
Supporting information
  • VSCode Version: Version 1.28.2 (1.28.2)
  • OS Version: Mac OS Mojave, Version 10.14
  • Other extensions installed: other than Particle, only PrintCode
Steps to Reproduce:
  1. Particle Create New Project
    2.Particle Compile application [local]
Launch with code --disable-extensions to check.
Does this issue occur when all extensions are disabled?: YES
Same problem over here. Any answer?
Have tried moving sources to all logical folders.
I have development folders on iCloud drive. The workspace is in an iCloud drive folder. I moved the folder to the local drive and then the build task worked.
@sdcsdcsdc - thanks for the report. do you mind re-trying using the latest build? i suspect at the least you’ll get a more helpful error message.
Same problem: no file found- tried with latest build, opened New Folder, created new Particle Project.
However, and props to steelydev that folder was in a Dropbox. When I create a new folder in a non-shared folder, compilation works.
