Could not find task: Compile application (local)
I’m running Windows 10 with an install from ParticleWorkbenchInstaller.exe
I haven’t used Workbench for over a month, when I came back to it I can no longer compile locally.
I created a new project, opened the .ino file, installed compiler toolchain 1.5.0 for an Argon, configured the project for my device, and then tried to perform a local compile.
I get: image
I have uninstalled, power cycled and re-installed from a fresh download off the website. I can compile in CLI
Here is from the terminal:
PS C:\B\Particle_Programs\tester\workplease> particle compile argon
Compiling code for argon
Including:
src\workplease.ino
src\workplease.cpp
project.properties
downloading binary from: /v1/binaries/5e8ba6903cffc30001e34789
saving to: argon_firmware_1586210410410.bin
Memory use:
text data bss dec hex filename
4844 108 1020 5972 1754 /workspace/target/workspace.elf
Compile succeeded.
Saved firmware to: C:\B\Particle_Programs\tester\workplease\argon_firmware_1586210410410.bin
Which is a cloud compile. But if I ask for Particle: Cloud Compile , I get:
When I open the developer tools console and run Particle: Compile application (local) I get:
The output of the error log is:
I only have the needed extensions installed:
What can I check/change to get the local compile pointed to the right location?
Ping @m_m
EDIT:
Does cleaning help?
Screenshot from 2020-04-06 21-32-42
I’m not convinced that leading forward slash is supposed to be there
Can you share a screenshot of your entire (including status bar at the bottom) Workbench Window with the Explorer (image) open?
The clean task could not be found either.
How would I remove the slash at the front? Where can I edit where it looks fro certain tasks?
Can you glean anything fro this? Let me know anything that would be good to look at.
hey there :wave: sorry for the bumps :pray:
i assume that means it was working at one point? if so, are you working with a project that you know once compiled fine?
have you updated VSCode recently? if not, give it a try:
looking at your screenshot above, i can tell Workbench is installed and running because you have our action buttons top-right as well as project settings displayed in the status bar.
try running Particle: Audit Environment as described here and share the non-sensitive bits in this thread.
beyond that, the only thing that caught my eye is the path /c:/B/Particle_Programs/tester/workplease - that seems wrong. is that project located on some sort of remote drive (e.g. dropbox, etc) or otherwise non-standard directory? if so, try creating a project in a standard directory.
the errors you are reporting are a bit odd in that you show "cannot find task" but then show the output from running that task so :man_shrugging:
Yes, I have had it working in the past. I’m not sure what I’ve changed since then.
I uninstalled VS Code, deleted the user data folders, and reinstalled from ParticleWorkbenchInstaller.
Now it works! It was the deleting of the %APPDATA%\Code and %USERPROFILE%\.vscode folders that did it.
Thanks for chirping in everybody.
