Just received Muon dev board with M404 msom. Current installed OS is 5.9.0 from tinker download. Saw note from rickkas that we could include particle-som-gnss lib to get GPS info on muon. 'When I compile it, I get an error stating the need for OS 5.8.2 or above. Inside particle workbench, when I use the OS dropdown I only see OS 5.8.0 that supports msom. How would I get OS 5.8.2 or above installed in workbench that supports msom?
You have to allow pre-releases. You probably just want to wait until the update for the DeviceOS integrates the GNSS integrated feature.
Thanks. After enabling the pre-releases, I was able to compile with the correct OS version.
