Just received the Muon dev board and M404. Did the setup and downloaded the tinker app and was successful at bringing it up via wifi. Now the muon has dropped offline multiple times for no apparent reason. Need to reset to bring back online. Running OS 5.9.0. The on-board status LED stopped breathing cyan and just shows solid cyan.
I have had issues with the tinker app, now only use the more supported services
Particle Workbench VS Code extension
Particle Set-up Site
This is for initial set up
Device Doctor
This is for fixing bricked devices
Particle Console
Viewing Data
Webhooks/Integrations
Connecting to external services and data storage
Particle.function() for user to SoM communication
Particle.publish() for SoM to user communication
Thanks for the info. I was able to compile new code and replace the tinker test app. The muon is staying connected and online now.
