[ISSUE] Can't flash tinker OTA after CLI update
Since CLI v2.7+ we can’t flash devices with tinker OTA anymore. The usual “particle flash <device_name> tinker” command fails with “Cannot read property ‘map’ from undefined”. One machine still running CLI v2.5 is fine though. Any thoughts?
Any help please? Also:
Windows 10, 64-bit
Installed from https://docs.particle.io/tutorials/developer-tools/cli/
Fails in PowerShell and cmd.exe
PS C:\Users\steph> get-childitem ~\AppData\local\particle
Directory: C:\Users\steph\AppData\local\particle
Mode LastWriteTime Length Name
d----- 8/5/2020 13:31 .npm-cache
d----- 4/8/2020 08:28 bin
d----- 4/8/2020 08:29 node-v12.16.1-windows-x64
d----- 8/5/2020 13:31 node_modules
d----- 4/8/2020 08:29 tmp
-a---- 8/13/2020 15:14 52 autoupdate
-a---- 8/13/2020 15:14 64627 error.log
-a---- 8/5/2020 13:31 636427 package-lock.json
-a---- 8/5/2020 13:31 59 plugin-cache.json
-a---- 6/27/2018 08:34 358689 Uninstall.exe
just tested over here - Windows 10 (1909), x64.
PS C:\Users\me\projects\test> particle flash myargon tinker
attempting to flash firmware to your device myargon
Flash device OK: Update started
Flash success!
...same result when using a photon or electron - what type of device are you targeting? when you run the following in powershell: get-command particle - what do you get back?
in the meantime, it couldn't hurt to manually reset as updates can sometimes go oddly:
I followed the reset instructions, but same result. There was just a bin folder and Uninstall.exe left before running the update-cli if that means anything.
Running get-command, I get the following:
PS C:\Users\steph\AppData\local\particle> get-command particle
CommandType Name Version Source
Application particle.exe 0.0.0.0 C:\Users\steph\AppData\Local\particle\bin\particle.exe
photons.
do you have dfu-util installed?
get-command dfu-util
if that returns something, run dfu-util --version and share the output of both commands
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Try the new cross-platform PowerShell https://aka.ms/pscore6
PS C:\Users\steph> get-command dfu-util
Application     dfu-util.exe                                       0.0.0.0    C:\Users\steph\AppData\Local\particle\bin\dfu-util.exe
PS C:\Users\steph> dfu-util --version
dfu-util 0.8
please run particle flash <your-device-name> tinker --verbose and share the complete error log
Windows PowerShell
PS C:\Users\steph> particle flash ********* tinker --verbose
attempting to flash firmware to your device **********
Failed to flash ***********: Cannot read property 'map' of undefined
VError: Failed to flash ************: Cannot read property 'map' of undefined
    at createAPIErrorResult (C:\Users\steph\AppData\Local\particle\node_modules\particle-cli\dist\cmd\cloud.js:883:17)
    at C:\Users\steph\AppData\Local\particle\node_modules\particle-cli\dist\cmd\cloud.js:255:13
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    at async CLI.runCommand (C:\Users\steph\AppData\Local\particle\node_modules\particle-cli\dist\app\cli.js:160:7)
    at async CLI.run (C:\Users\steph\AppData\Local\particle\node_modules\particle-cli\dist\app\cli.js:190:14)
caused by: TypeError: Cannot read property 'map' of undefined
    at ParticleApi.flashDevice (C:\Users\steph\AppData\Local\particle\node_modules\particle-cli\dist\cmd\api.js:127:20)
    at C:\Users\steph\AppData\Local\particle\node_modules\particle-cli\dist\cmd\cloud.js:277:26
ah, ok. found it! thanks for your patience :pray:
it seems your device is a member of a product. i’ll get a fix together ASAP but in the meantime you can work around the problem by running:
particle cloud flash <device-id> tinker --product <product-id>
for more options & info, see:
particle cloud flash --help
That worked correctly. Fantastic. Thanks for your help.
Oh, I also got a new message that the device was marked development. This device may have already been marked development, but is that a new change? Was it letting me know it was marked development, or will it mark the device development automatically going forward?
yes, if the target device was already in development mode it's essentially a no-op but it'll still show the note just as a reminder
Nice. That’s really helpful considering all the times our manual flashes were immediately reverted. :slight_smile: Thanks again for the help.
Just noticed v2.8.1 seems to fix the problem. Thanks again!
