Is it possible to flash a Core from firmware via the web interface?
I would like to share the firmware I compiled with a friend so that he can test it on his Core.
However, he is not comfortable with the command line, and I wonder if it is possible to do one of the following:
  1. For me to flash his Core remotely if I know its ID, even though I do not own it.
  2. For him to upload the firmware to the Spark Cloud / web editor, and from there to flash his Core with it.
Thank you for your help!
Look at the command here:
http://docs.spark.io/api/#verifying-and-flashing-new-firmware-flash-a-core-with-a-pre-compiled-binary
You will need an access token and the core id
# EXAMPLE REQUEST IN TERMINAL TO FLASH A BINARY
curl -X PUT -F file=@my-firmware-app.bin -F file_type=binary \
  "https://api.spark.io/v1/devices/0123456789abcdef01234567?access_token=1234123412341234123412341234123412341234"
