Is Electron surface mountable?
Sorry if this question has a well known answer.
I am new here …
You may search for “E Series” which will be the SMT version of the Electron - the Electron itself is due to its bottom mounted components not surface mountable as such.
https://www.particle.io/products/hardware/particle-e-series-industrial-cellular-iot-modules
And there is no way by cutting a hole for the bottom components?
Thank you Scruffr.
There might be, but why would you want to do that, considering a dedicated SMT version is on the way?
