Has anyone run into this issue? Whenever I build my project I get the following:
Undefined symbols for architecture x86_64:
“OBJC_CLASS$_SparkCloud”, referenced from:
objc-class-ref in ViewController.o
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
I am using Xcode 8.2.1
Ay help is much appreciated. Been stuck on this all day.
Wondering if this a version issue? A little more about the issue. I was able to use cocoa pods about 3 months ago on a 2014 MacBook Pro. I recently upgraded to the new MacBook Pro. Not sure which version of cocoa pods I was using, but I am thinking maybe if I roll back a few version it would Solve the issue. Just a thought.
@ido , Below is my pod file. I have tried many different variations of this that I found on the forum, all produce the same error. The pod file did install successfully. I get the same error when I run on a device.
# Uncomment this line to define a global platform for your project
# platform :ios, '9.0'
target 'shades' do
# Comment this line if you're not using Swift and don't want to use dynamic frameworks
use_frameworks!
# Pods for shades
target 'shadesTests' do
pod “Spark-SDK”
inherit! :search_paths
# Pods for testing
end
target 'shadesUITests' do
# Pods for testing
end
end
Well there we go, please remove the use_frameworks! directive and try again (after running pod install) - as the iOS SDK is built as a library and not as a framework. If you prefer/need to use frameworks revert to using the Carthage version of the SDK.
