Error while building IOS xcode for particle login
hello team,
I am trying to login to spaekcloud using ios . i build the code using xcode and followed the steps here https://www.youtube.com/watch?v=_aotVQGhPH8 ,https://www.youtube.com/watch?v=IR8WJauWUVc. i am not able to login as i came across this error below, i have been working on it from past 1 week , i see that its a linking compiler and system issue i am using osx 10.11 el captain , xcode 7.3.1 . and my pod --version is 1.0.1 and i did everything available on internet but i wasnt successfull can you help me solving this issue:
Undefined symbols for architecture i386:
“OBJC_CLASS$_SparkCloud”, referenced from:
type metadata accessor for __ObjC.SparkCloud in ViewController.o
ld: symbol(s) not found for architecture i386
Undefined symbols for architecture x86_64:
ld: symbol(s) not found for architecture x86_64
Pinging our iOS developer @ido here !!
thank you mohit
Swift or Obj-C project?
Do you use cocoapods or carthage?
I used cocoapods , swift project.
hello ido,
can you pls help me solve the issue asap. let me know when your available i need to close this.
@ido I am running into this same issue. Looks like I am not alone.
