I did a particle update on a Photon and then a particle identify and was a bit surprised to see version 1.0.0. However, progress is usually a good thing. I then ran the Particle iOS app and asked it to reflash Tinker, which it did. However, whenever I try to turn on D7, I get a hard fault. I downloaded and flashed the new Tinker 1.0.0 app and all is good. So…I had the iOS app re-flash Tinker and the problem re-appeared. I’m guessing, the iOS Particle app is flashing an older version of Tinker that’s not compatible with 1.0.0 and should be updated.
