Interface LIS3DHTR with Particle to make tap detection solution
Hello, Does anyone use LIS3DHTR with the particle?
I want ot make the tap detection solution through datasheet but if anyone worked this kind of tap detection before kindly share some of your advices to make it work with Particle photon.
The LIS3DH is the accelerometer on the AssetTracker GPS boards. The Adafruit library can be used. I use my LIS3DH library.
I’ve never done the tap detection, though it’s just a few different register settings so I don’t see any reason why it wouldn’t work.
