I’m trying to use NFC to initiate a BLE connection between a phone and a particle board (Argon or Xenon). I then want to send data from the board to the phone over bluetooth. I’m just looking to build a proof of concept and don’t care too much of security. Any thoughts on if this is possible? Any resources that explains how this works?
I think this would be a good starting point for the fundamentals
After that have a look here - particularly the examples - for the BLE side of the pairing process
https://docs.particle.io/tutorials/device-os/bluetooth-le/
And then here to setup the virtual NFC tag on your device to present the required data
https://docs.particle.io/reference/device-os/firmware/argon/#example-app
This may also be interesting
