I’m having a problem understanding the purpose of repeated Event “spark/watch/var/myVariable”.
I’ve been working on some projects and I wrote this small example to show you the problem I’m trying to figure out… So I created this simple function on my Boron:
SYSTEM_THREAD(ENABLED);
int myVariable;
Particle.function("myFunction", myFunction);
Particle.variable("myVariable", myVariable);
int myFunction(String command)
myVariable = command.toInt();
Particle.publish("My Variable is: ", String(myVariable), PRIVATE);
return 0;
and then I created a simple Button Applet on IFTTT.
When Button is pressed, IFTTT is supposed to read the Value of myVariable and if its greater than 4 it sends me a Pushover Notification.
So for example I changed myVariable to 7, everything seems to work fine except! Im getting " spark/watch/var/myVariable" repeated every 30 seconds to 1 minute until I reboot the Boron.
Even though if I lower myValue to 3 it will keep flooding.
Is there any way to limit those events from appearing? I think its counting towards the Data Usage/Operations.
Thank you
