I don’t know if it is intentional that IF recipes are creating Dashboard events - so if this is the case than ignore this
Here is a snapshot of my dashboard showing ‘91’ events which are reflecting a cloud variable:
They actually belong to my IFTTT recipe:
And even disableing it does not turn off the dashboard events. It does turn off the iOS event defined in the recipe.
good to know - this was only a coincicence that I had a recipe on online/offline.
Then back to the cloud variable based recipes: here is the data from the beginning of this thread which floods the dashboard even if disabled. Also of you had it enabled and then delete the recipe it still triggers:
create a recipe to monitor a cloud variable triggering an iOS notification
open the dashboard & and wait for the first event to arrive
disable the recipe
The notations on the phone stop after the last step but the dashboard still gets the events. Even after deleting the recipe the events still arrive. Reloading the dashboard does not stop them, even closing the page and reopening does not help any more.
