https://api.particle.io/v1/products/:productSlug/device_claims? not found
I’m trying to add customer to my product.
  1. I created the customer
  2. Get it token
  3. And I try to get claim code for it.
For it I use following API point and it construction:
https://api.particle.io/v1/products/beerlogger-v01/device_claims?access_token=:customerToken
but in answer I get:
{"ok":false,"error":"Not Found"}
How I can do it in the right way?
Maybe have a run of this command to list your products:
https://docs.particle.io/reference/api/#list-products
From the data returns, you will find a number of items of interest including:
  • id
  • product_id
  • name
  • slug
In your example, you are providing the value “beerlogger-v01” for the parameter known as “productIdOrSlug”. Can we compare that value vs the product record returned through a list? I have a suspicion that you are not mapping the correct value and may be using name or or some other parameter. Try the “product_id” or “slug” values from the retrieved record.
