How to publish location event?
I have Particle Tracker One device and I´m working with Particle Edge firmware.
I would like to do next:
  • when my SoC (for ex.70) changes +/-5 (75 or 65) I would like to trigger a location event.
    if(abs(start_soc - batt_soc)>5){
    //trigger the event
    start_soc = batt_soc;
    …How to trigger location event?
You can call this to trigger a location publish from user firmware:
TrackerLocation::instance().triggerLocPub();
Just one more question. Is there a function that can be called from user firmware that reboots device?
System.reset() :wink:
Tracker Edge will do a few things internally to reset gracefully. System.reset() will work as it is captured in the following snippet to stop some running processes first.
// Associate handler to OTAs and pending resets to disable the watchdog
System.on(reset_pending,
    [this](system_event_t event, int param){
        // Stop everything
        stop();
        end();
