Defaulft “cmd” Function with {“cmd”:“get_loc”}
I really like the output that I get when using {“cmd”:“get_loc”}
Is there any way to trigger this event outside that “cmd” Function?
I would like it to be triggered by an event, a sensor value like speed, etc.
Thank you
#include "Particle.h"
#include "tracker_config.h"
#include "tracker.h"
SYSTEM_THREAD(ENABLED);
SYSTEM_MODE(SEMI_AUTOMATIC);
PRODUCT_ID(TRACKER_PRODUCT_ID);
PRODUCT_VERSION(TRACKER_PRODUCT_VERSION);
SerialLogHandler logHandler(115200, LOG_LEVEL_TRACE, {
{"app.gps.nmea", LOG_LEVEL_INFO},
{"app.gps.ubx", LOG_LEVEL_INFO},
{"ncp.at", LOG_LEVEL_INFO},
{"net.ppp.client", LOG_LEVEL_INFO},
int ControlPanel(String command);
Particle.function("ControlPanel", ControlPanel);
Particle.connect();
void loop() {}
if (command == "info_center")
// I WOULD LIKE TO USE THAT {"cmd":"get_loc"}
// TO TRIGGER "loc" Event to obtain JSON file
return 1;
else
return -1;
