With the P2/Photon2 devices they can connect to 5GHz as well as 2.4 GHz. If the SSID does not specifically include 5GHz - can one assume that channels 36 and above are 5GHz and not 2.4 GHz?
There isn't a separate field for 5 GHz, so the channel number is probably the best option.
