How to create a 5 Volt PWM signal
Context: I need to create a PWM signal to control a fan’s speed. The fan is a 230 Volt fan, so the PWM is only a control signal. The PWM signal should be between 5 and 10 Volt and between 5 and 10 KHz. The duty cycle determines the fan’s speed.
I have a small circuit that will create a 5V PWM signal from the 3.3 Volt signal from one of the Argon I/O pins. But I need a 5V power soirce for that. The Argon will preferably be connected to a USB cable. That means that there is 5V avalable, but I am not sure if I can connect to it when the power is provided tghrough the USB port, would VUSB work?
Alternatively, I could probably strip the USB cable and connect the VCC and GND to the VUSB and GND pins, but I would prefer to just use the USB cable.
Yes, if you are powering by USB, the VUSB pin will be a 5V output and you can use it to power other things at 5V.
I would connect that a P-channel MOSFET and the gate to a GPIO. Just be careful on Gen 3 devices (Argon, Boron, Xenon) to not apply 5V to any GPIO pins directly, as they are not 5V tolerant.
Hi, thanks for the confirmation an the tip regarding the Mosfet. I’ll look into that
