I’m migrating from Argon to Boron, and I had a wake on PWR which is the VUSB pin, however I do not see any similar tie in the Boron, but there is the WKP pin on D8. Can I tie VUSB to D8 directly, or do I need some circuitry (resistors or diodes or something) in between them?
Does the answer differ if I am supplying the Boron’s power over the micro-USB or by putting 5v on the VUSB pin?
