How to communicate between Electrons wirelessly using either Bluetooth or nRF24L01+?
I have the RFM95w Radios working directly with the Photon which should also work with the Electron. I used the Adafruit Feather with RFM95w to communicate between the two.
You can get long range with these radios but you can dial down the power if you don’t need that much range also.
The code to do this is here: Photon LoRaWAN node?
