Hey Particle Team, I am trying to create a switch case that can be called from Particle.function to change device useCase. I have a bunch of errors, would love some feedback on this!
#include "Particle.h"
#include "tracker_config.h"
#include "tracker.h"
#include "Air_Quality_Sensor.h"
#include "Adafruit_BME280.h"
#define AQS_PIN A2
SYSTEM_THREAD(ENABLED);
SYSTEM_MODE(SEMI_AUTOMATIC);
PRODUCT_ID(TRACKER_PRODUCT_ID);
PRODUCT_VERSION(TRACKER_PRODUCT_VERSION);
SerialLogHandler logHandler(115200, LOG_LEVEL_TRACE, {
{ "app.gps.nmea", LOG_LEVEL_INFO },
{ "app.gps.ubx", LOG_LEVEL_INFO },
{ "ncp.at", LOG_LEVEL_INFO },
{ "net.ppp.client", LOG_LEVEL_INFO },
// Library: Grove_Temperature_And_Humidity_Sensor
AirQualitySensor aqSensor(AQS_PIN);
Adafruit_BME280 bme;
// Sample the temperature sensor every 2 seconds. This is done so the outlier values can be filtered out easily.
const unsigned long CHECK_PERIOD_MS = 2000;
unsigned long lastCheck = 0;
int useCaseState = 0; // useCase 1 = Cold Chain(temp/humid), useCase 2 (AQM) = , useCase 3 = (pressure)
void locationGenerationCallback(JSONWriter &writer, LocationPoint &point, const void *context); // Forward declaration
Tracker::instance().init();
aqSensor.init();
bme.begin();
Particle.function("Input",thisUseCase);
// Callback to add key press information to the location publish
Tracker::instance().location.regLocGenCallback(locationGenerationCallback);
Particle.connect();
Tracker::instance().loop();
if (millis() - lastCheck >= CHECK_PERIOD_MS) {
lastCheck = millis();
thisUseCase (String input){
if input = "Cold Chain"
useCaseState = 1;
if input = "heavyTrucking"
useCaseState = 2;
if input = "railCar"
useCaseState = 3;
// put in some function and let it redirect
callback (input){
parseFunction();
parseFunction (input){
switch (useCaseState){
case 1: coldChain()
break;
case 2: railCar()
break;
case 3: heavyTrucking()
break;
coldChain (){
// Read Measurments from BME 280
int temp = (int)bme.readTemperature();
int humidity = (int)bme.readHumidity();
// Add Names under device page
writer.name("Temperature").value(temp, 1);
writer.name("Humidity").value(humidity, 1);
railCar (){
int pressure = (int)(bme.readPressure() / 100.0F);
writer.name("Pressure").value(pressure, 1);
heavyTrucking(){
// Read Measurments from Air Quality v1.2
// Persona 2
int quality = aqSensor.slope();
String qual = "None";
if (quality == AirQualitySensor::FORCE_SIGNAL)
qual = "Danger";
else if (quality == AirQualitySensor::HIGH_POLLUTION)
qual = "High Pollution";
else if (quality == AirQualitySensor::LOW_POLLUTION)
qual = "Low Pollution";
else if (quality == AirQualitySensor::FRESH_AIR)
qual = "Fresh Air";
// Write AQ under Device Page
writer.name("Quality").value(qual, 15);
You may want to re-read what I wrote above and try to understand what I meant.
If I didn’t express myself clearly enough, quote the statement and explain what was not clear
Finally you introduced a new mistake with this
You are using the functionuseCaseState() like a variable which will not work the way you expect it to do - although it probably will only produce a warning rather than an error.
