The blinking cyan has nothing to do with keys - this would be the orange burst issue
Do you see an orange burst?
Blinking cyan is most likely caused by your device not being able to connect to your WiFi.
What encryption are you using?
Have you checked the network requirements?
Can you try supplying the WiFi credentials via a serial monitor or CLI particle serial wifi (don’t scan for networks if you want to be sure)?
