The .tar file requires some more actions to get it running which I've never bothered to do. I suggest you try the file in this post:
It's precompiled, and should work right out of the (drop)box.
Then open command prompt in the same directory as you've saved that file, and try the actions from the guide again, they should work.
Let me know if that worked out for you!
