Hi everyone,
I'm trying to build the Tachyon kernel from the following repository:
https://github.com/particle-iot/tachyon-ubuntu-24.04-kernel
According to the documentation, it seems the kernel should be built natively using Docker:
However, I couldn't find any Dockerfile in the repository, so I'm not sure how the Docker-based native build is supposed to work.
As an alternative, I tried cross-compiling the kernel using the standard KBuild method with the commands below, but it fails with build errors:
make -j8 O=kernel_out ARCH=arm64 CROSS_COMPILE=/usr/bin/aarch64-linux-gnu- qcom_defconfig
So I wanted to ask:
Is cross-compiling the Tachyon kernel officially supported?
If cross-compilation is supported, am I using the wrong build commands or missing some required setup?
Where can I find the Dockerfile (or Docker build environment) referenced in the documentation?
Any guidance would be greatly appreciated. Thanks!
