GPS Shield Issues - Electron Asset Tracker
@copterview here is a link to my other post that talks about "quick" fixing of positions and the first time
Basically, the first time I had to take mine for a drive, make sure the coin cell is installed, then it would fix quickly after the first lock.
The only issue I notice with it now, is if its not outside, the location can be off by over 100m (~300ft). Likely because indoors its lucky to get even 1 satellite fix.
