Hi there,
I've searched through the forums and have seen similar issues to the one I'm facing but haven't found an actual resolution.
I've got a working API key and a paid google account for usage w/ the Maps API but I'm seeing a 404 on the responses to my location events in the Particle console logs.
When taking the same query that's throwing the errors and make the API call w/ Postman, the response is good and solves a GPS location. Any one else experience this or have any insights as to what to do about it?
thanks in advance.
-CWD
I think you might be experiencing the problem in this post. There isn't a general-purpose solution at this time.
It does appear to be the RAT issue in the previous post. I was able to reproduce a 404 with the built-in Google Maps device locator integration.
As a workaround, you can use the technique in this Github. It's fully compatible with the device firmware for the official Google Maps device location integration, but instead of using the built-in integration, you create a custom webhook. The page shows how in the Creating a Webbhook section.
Using that technique I was able to successfully geolocate. Make sure you disable your Google Maps integration so you don't have both running at the same time.
