I want to activate the GPS module of the m524 module, which is integrated into the cellular module of the chip. However, I cannot find the necessary documentation for this. Is there any example or documentation to obtain this information from the main code?
Take a look here!
M524 support is currently being tested on a separate branch. The library as published only supports M404.
(The modem is a different model).
