Function call failed Timed out
particle flash --usb tinker should do the trick.
Hey folks! We did some investigation this morning and believe we may have found the root cause. The issue was not consistent across all v060 devices, so we don’t currently believe it’s a firmware issue.
The device IDs that were reported had gotten into a weird state with our device broker so we restarted the service and it seems to be improved. We’d very much appreciate if you’d check the affected devices and let us know if the symptoms are resolved!
Yes! I just successfully sent a function call for the first time in two days. Excellent, thank you.
