Request to Particle Hardware Team - I am using Fritzing to design and layout various solutions I am working on. Someone had already defined a community part for a Spark Core V1.0 and I wanted to create and share a new part for the Particle photon.
In the latest version of the Parts Editor there are six tabs: Breadboard view, Schematic view, PCB view, Icon view, Metadata view, and Connectors view. As you might expect, the first four views are for the part images; the Metadata view is where you enter the part’s title, author, and other properties; and the Connectors view is for editing connector metadata, and for adding or removing connectors.
To complete this I require the following:
- particle logo with photon name in SVG format for the icon view
- particle photon schematic in SVG format for the schematic view
- particle photon board land pattern eagle file on github - photon/libraries/Spark.lbr
Under the docs.particle.io data sheets for photon I can only access .PNG images and I am unable to download/clone to local git the eagle file. I could create SVG files but thought I would ask to see if you have any?
