Hi there @Support ,
are there any special considerations if one wants to OTA update a fleet of Borons from 1.5.1 into 4.2.0?
Any in-between updates that must be done, or the devices can go from 1.5.1 to 4.2.0 without issues?
Hi there @Support ,
OTA? When upgrading OTA all upgrade combinations should work because the cloud will insert a required update automatically if necessary.
For each new Device OS release, a number of versions from 1.4.2 and later are tested for OTA upgrade. 1.5.1 is one of the tested versions and passed upgrade to 4.2.0.
I want to add that the transition beyond 3.1.0 doubles the binary size, so while it's not risky, it just takes longer than you'd expect from previous versions.
Thank you both!
