I set up my Proton today and started testing some code on it. At some point though, flashing code to the Proton didn’t update the program on it (it did flash magenta, though).
After reseting the Proton, deleting it from my list of devices and re-adding it through the webinterface (the Android app seems not to be capable of re-adding devices which were previously linked to your own account), the error still persists - I see the device as online, it breathes and I can use the flash-button - but after the magenta, green and cyan blinking the device just falls back to breathing cyan.
Is there any solution to this? I can’t use DFU right now but might be able to use it sometime this weekend …
Found DFU device 2b04:d006
Apparently I didn't find a DFU device? util said dfu-util 0.8
Deducing device DFU version from functional descriptor length
Found DFU: [2b04:d006] ver=0200, devnum=2, cfg=1, intf=0, alt=1, name="@DCT Flash /0x00000000/01*016Kg", serial="00000
000010C"
Found DFU: [2b04:d006] ver=0200, devnum=2, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/03*016Ka,01*016Kg,0
1*064Kg,07*128Kg", serial="00000000010C"
checking file downloads/firmware.bin
spawning dfu-util -d 2b04:d006 -a 0 -i 0 -s 0x080A0000:leave -D downloads/firmware.bin
dfu-util 0.8
Invalid DFU suffix signature
ID 2b04:d006
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 2072
Download [=========================] 100% 2072 bytes
Download done.
File downloaded successfully
Error during download get_status
Error writing firmware...
Edit: Oh, but the code runs despite the error
Edit2: But flashing another code from the webinterface still doesn’t work.
