Flashed Photon code to a Core
Arrrrr. I flashed Photon code to a Core by mistake (working on too many things at once and had the wrong terminal window open). Now the Core is flashing yellow and if I restart the Core it IMMEDIATELY begins flashing yellow. Can I recover the situation? Ooooooops. I will try Particle Doctor.
So stupid of me…
With the Core there’s always the Factory reset. Or DFU programming.
Factory reset worked! Thanks!
