Hello everybody,
As far as I’m aware this hasn’t been requested before, so I thought I’d give it a try.
Would it be possible for the Spark team to add a feature to the apps that would allow us to flash firmware through it?
By that I do not mean program through it (which might be neat in a later stadium) but just flash your already existing apps. Personally I’ve got quite a few ‘test apps’ which I’d like to switch around to see if they make any significant differences. Although this is possible through the web IDE, it would be really nice if we could flash these using the native apps.
I was thinking that you might be able to add it under the “re-flash Tinker” button. You could create some kind of list with your apps, which you could then flash at will.
Not sure if this is something you’re willing to spend time on at the moment, but I guess it doesn’t hurt to ask
Thanks in advance, you’re doing a great job on all of this!
