I think the web IDE is unstable as is atm, I hit ctrl+Enter and it goes “Flash successful”, then the particle goes into Magenta light, the LED goes off and then back to Magenta, starts to flash Cyan, then rapid red, then slow red, then rapid, then goes to White and then blinks cyan to yellow, then cyan rapid and then into permanent cyan.
But after doing ^ it comes up with the previous firmware.
I’ve tried to remedy it by turning the chip into DFU mode and then doing particle update. So it works a little bit after that but then starts to break again after a little while.
So I don’t know what’s wrong.
