Hi everyone,
I don’t wanna open the new thread in this matter I, just want to share with what I achieved with simple arduinoFFT mixed with adafruit example by using the method “copy-paste-try”. My goal was simple make the 3 LED’s reacting just low(red), mid(green), and treb(blue) spectrum, just like old style “disco pod lights”. The final effects are impress me as everybody are talking no is not possible !!! no you can’t analyse audio spectrum without dedicated processor with special super mega DSP and et cetera et cetera … So I tested entire toy with some sin wave gen app and small Sony boombox. and is working just as expected !
What is weird for me, is that all examples on entire internet shows FFT spectrum analiser with sample rates 9000Hz even the adafruit example is just analyser of spectrum from 0-4500Hz and then output results is showing blinking leds but without any sense for me something is blinking there but what exactly I don’t know. I’m able to analyse the spectrum from 50Hz to 18kHz and even if I “pretend” (with my mouth) low (hummmmm), mid(whistling), treb(the rustling)
the leds reacting appropriately.
My Led’s are not neo pixels is my DIY project which I make couple years ago just for learning. On the board I have 3 x AD5241 I2C Compatible, 256-Position Digital Potentiometers , 3 x NE555 as adjustable PWM and 3 x CAT4101 as a power LED’s driver. I do not use any special lib. for AD5241 just simple “registers write” regarding to the data from manual. Photon is communicating via I2C with AD5241 and AD5241 is adjusting NE555 PWM output then NE555 is driving CAT4101 that’s it. Microphone is connected to A0 i used adafruit Electret Microphone Amplifier - MAX9814 with Auto Gain Control
Regarding the code i modify couple things also ArduinoFFT has to be modified a litle and attached manually on web IDE. And I have some questions.
- Why we need calculate weird x
double x = chroma*(1.0-fabs(fmod(h1, 2.0)-1.0));
when for hue 0, 120.0, 240.0 will always be 0 ?
- why we need to spreed windows size evenly ? in this approach we gonna have low mixed with mid and mid mixed with treb and (something is blinking but what is this ? i don’t know)
- why my approach is working perfect ? regarding to many examples should’t even work.
4 why we need special fast “super-duper” FFT lib. ? when is working with the simple one ?
Maybe my code doesn’t make any sense and is working just “by accident”
but my goal is reached !
Here is the code:
// Audio Spectrum Display
// Copyright 2013 Tony DiCola (tony@tonydicola.com)
// borrowed and modified by Arek Otreba
// This code is part of the guide at http://learn.adafruit.com/fft-fun-with-fourier-transforms/
#include "Particle.h"
#include <SparkIntervalTimer.h>
#include "arduinoFFT.h"
void samplingCbISR(); // forward declaration
// CONIFIGURATION
// These values can be changed to alter the behavior of the spectrum display.
IntervalTimer samplingTimer;
#define CHANNEL A0 // Input ADC pin for audio data.
#define INDICATOR_LED_PIN D7 // feedback indicator
#define blue 0x2C // blue LED address
#define red 0x2D // red LED address
#define green 0x2F // green LED address
#define reg1 0x00 // from AD541X manual
#define reg2 0X00
#define AD524X_O1_HIGH 0x10 // AD5241 output O1
#define AD524X_O2_HIGH 0x08 // AD5241 output O2
int SAMPLE_RATE_HZ = 54000; // Sample rate of the audio in hertz.
float SPECTRUM_MIN_DB = 60.0; // Audio intensity (in decibels) that maps to low LED brightness.
float SPECTRUM_MAX_DB = 90.0; // Audio intensity (in decibels) that maps to high LED brightness.
const uint16_t FFT_SIZE = 256; // Size of the FFT. Realistically can only be at most 256
int LED_COUNT = 3; // Number of Aro pixels.
uint8_t win_type = FFT_WIN_TYP_RECTANGLE;
uint8_t dir = FFT_FORWARD;
double vReal[FFT_SIZE];
double vImag[FFT_SIZE];
int sampleCounter = 0;
double frequencyWindow[4] = {50.0,900.0,5000.0,18000.0};
double hues[3];
bool windowing = true;
double saturation = 1.0;
double low = -2.0;
double mid = 0.2;
double treb = 0.6;
arduinoFFT FFT = arduinoFFT(); // Create FFT object
// MAIN SKETCH FUNCTIONS
SYSTEM_MODE(AUTOMATIC);
setADCSampleTime(ADC_SampleTime_3Cycles);
Wire.begin();
delay(20);
writeReg(red, reg2, 0);
writeReg(green, reg2, 0);
writeReg(blue, reg2, 0);
Particle.function("CONTROLL", controll);
Serial.begin(115200);
Serial.println("Ready");
pinMode(INDICATOR_LED_PIN, OUTPUT);
// Initialize spectrum display
spectrumSetup();
// Begin sampling audio
samplingBegin();
// Calculate FFT if a full sample is available.
if (samplingIsDone()) {
// Run FFT on sample data.
if(windowing){
FFT.Windowing(vReal, FFT_SIZE, win_type, dir);
FFT.Compute(vReal, vImag, FFT_SIZE, FFT_FORWARD); /* Compute FFT */
// Calculate magnitude of complex numbers output by the FFT.
FFT.ComplexToMagnitude(vReal, vImag, FFT_SIZE); /* Compute magnitudes */
spectrumLoop();
// Restart audio sampling.
samplingBegin();
// UTILITY FUNCTIONS
// Compute the average magnitude of a target frequency window vs. all other frequencies.
void windowMean(double* vReal, int lowBin, int highBin, double* windowMean, double* otherMean) {
*windowMean = 0;
*otherMean = 0;
// Notice the first magnitude bin is skipped because it represents the
// average power of the signal.
for (int i = 1; i < FFT_SIZE/2; ++i) {
if (i >= lowBin && i <= highBin) {
*windowMean += vReal[i];
else {
*otherMean += vReal[i];
*windowMean /= (highBin - lowBin) + 1;
*otherMean /= (FFT_SIZE / 2 - (highBin - lowBin));
// Convert a frequency to the appropriate FFT bin it will fall within.
int frequencyToBin(double frequency) {
double binFrequency = double(SAMPLE_RATE_HZ) / double(FFT_SIZE);
return int(frequency / binFrequency);
// Convert from HSV values (in floating point 0 to 1.0) to RGB colors usable
// by neo pixel functions.
uint32_t pixelHSVtoRGBColor(double hue, double saturation, double value) {
// Implemented from algorithm at http://en.wikipedia.org/wiki/HSL_and_HSV#From_HSV
double chroma = value * saturation;
double h1 = double(hue)/60.0;
double x = 0.0; //chroma*(1.0-fabs(fmod(h1, 2.0)-1.0)); no need to be calculated for hue 0,120,240 will always be 0
double r = 0.0;
double g = 0.0;
double b = 0.0;
Serial.print("HUE");
Serial.println(hue, 4);
Serial.print("CHROMA");
Serial.println(chroma, 4);
Serial.print("WEIRD_X");
Serial.println(x, 4);
int R = 0;
int G = 0;
int B = 0;
if (h1 < 1.0) {
r = chroma;
g = x;
else if (h1 < 2.0) {
r = x;
g = chroma;
else if (h1 < 3.0) {
g = chroma;
b = x;
else if (h1 < 4.0) {
g = x;
b = chroma;
else if (h1 < 5.0) {
r = x;
b = chroma;
else // h1 <= 6.0
r = chroma;
b = x;
float m = value - chroma;
r += m;
g += m;
b += m;
if(0.0 >= h1 && h1 <= 2.0){
if(r == 0){
writeReg(red, reg2, int(255*r));
else{
writeReg(red, AD524X_O1_HIGH, int(255*r));
if(2.0 >= h1 && h1 <= 4.0 ){
if(g == 0){
writeReg(green, reg2, int(255*g));
else{
writeReg(green, AD524X_O1_HIGH, int(255*g));
if(4.0 >= h1 && h1 <= 5.0){
if(b == 0){
writeReg(blue, reg2, int(255*b));
else{
writeReg(blue, AD524X_O1_HIGH, int(255*b));
Serial.print("R1 ");
Serial.println(r,3);
Serial.print("G1 ");
Serial.println(g, 3);
Serial.print("B1 ");
Serial.println(b, 3);
// SPECTRUM DISPLAY FUNCTIONS
void spectrumSetup() {
// Set the frequency window values by evenly dividing the possible frequency
// spectrum across the number of neo pixels.
double windowSize = (SAMPLE_RATE_HZ / 2.0) / double(LED_COUNT);
for (int i = 0; i < LED_COUNT+1; ++i) {
frequencyWindow[i] = i*windowSize;
// making windows size evenly doesn't make any sense for me.
// Evenly spread hues across all pixels.
for (int i = 0; i < LED_COUNT; ++i) {
hues[i] = 360.0*(double(i)/double(LED_COUNT));
void spectrumLoop() {
// Update each LED based on the intensity of the audio
// in the associated frequency window.
double intensity, otherMean;
windowMean(vReal, frequencyToBin(frequencyWindow[i]), frequencyToBin(frequencyWindow[i+1]), &intensity, &otherMean);
// Convert intensity to decibels.
if(i == 0){
intensity = (20.0 + low)*log10(intensity); // adiust intensivity red
else if(i == 1){
intensity = (20.0 + mid)*log10(intensity); // adjust intensivity green
else if(i == 2){
intensity = (20.0 + treb)*log10(intensity); // adjust intensivity blue
// Scale the intensity and clamp between 0 and 1.0.
intensity -= SPECTRUM_MIN_DB;
intensity = intensity < 0.0 ? 0.0 : intensity;
intensity /= (SPECTRUM_MAX_DB-SPECTRUM_MIN_DB);
intensity = intensity > 1.0 ? 1.0 : intensity;
pixelHSVtoRGBColor(hues[i], saturation, intensity);
// communication with AD524X
void writeReg(byte device, byte reg, int Data)
Wire.beginTransmission(device);
Wire.write(reg);
Wire.write(Data);
Wire.endTransmission();
// Paticle controll function
int controll(String message){
// ex: setrelais:on
// ex: setrelais:off
// ex: setalarm:10
int colonPos = message.indexOf(":") ;
if (colonPos < 0) return -1 ; // syntax error not found
String command = message.substring(0,colonPos) ;
String argument = message.substring(colonPos+1) ;
if(command.equals("windowing")){
int pointer = argument.toInt();
if(pointer == 0){
windowing = false;
if(pointer == 1){
windowing = true;
return windowing;
else if(command.equals("samplehz")){
SAMPLE_RATE_HZ = pointer;
return SAMPLE_RATE_HZ;
else if(command.equals("spectrummin")){
double tempolary = argument.toFloat();
SPECTRUM_MIN_DB = tempolary;
return SPECTRUM_MIN_DB;
else if (command.equals("spectrummax")){
SPECTRUM_MAX_DB = tempolary;
return SPECTRUM_MAX_DB;
else if (command.equals("saturation")){
saturation = tempolary;
return saturation;
else if (command.equals("low")){
low = tempolary;
return low;
else if (command.equals("mid")){
mid = tempolary;
return mid;
else if (command.equals("treb")){
treb = tempolary;
return treb;
else if (command.equals("ledcount")){
LED_COUNT = pointer;
return LED_COUNT;
else if (command.equals("wintype")){
if(pointer == 0){
win_type = FFT_WIN_TYP_WELCH; /* welch */
return FFT_WIN_TYP_WELCH;
if(pointer == 1 ){
win_type = FFT_WIN_TYP_RECTANGLE; /* rectangle (Box car) */
return FFT_WIN_TYP_RECTANGLE;
if(pointer == 2){
win_type = FFT_WIN_TYP_HAMMING; /* hamming */
return FFT_WIN_TYP_HAMMING;
if(pointer == 3){
win_type = FFT_WIN_TYP_HANN; /* hann */
return FFT_WIN_TYP_HANN;
if(pointer == 4){
win_type = FFT_WIN_TYP_TRIANGLE; /* triangle (Bartlett) */
return FFT_WIN_TYP_TRIANGLE;
if(pointer == 5){
win_type = FFT_WIN_TYP_NUTTALL; /* nuttall */
return FFT_WIN_TYP_NUTTALL;
if(pointer == 6){
win_type =FFT_WIN_TYP_BLACKMAN; /* blackman */
return FFT_WIN_TYP_BLACKMAN;
if(pointer == 7){
win_type = FFT_WIN_TYP_BLACKMAN_NUTTALL; /* blackman nuttall */
return FFT_WIN_TYP_BLACKMAN_NUTTALL;
if(pointer == 8){
win_type = FFT_WIN_TYP_BLACKMAN_HARRIS; /* blackman harris*/
return FFT_WIN_TYP_BLACKMAN_HARRIS;
if(pointer == 9){
win_type = FFT_WIN_TYP_FLT_TOP; /* flat top */
return FFT_WIN_TYP_FLT_TOP;
else if (command.equals("dir")){
if(pointer == 0){
dir = FFT_REVERSE;
return FFT_REVERSE;
if(pointer == 1 ){
dir = FFT_FORWARD;
return FFT_FORWARD;
else if (command.equalsIgnoreCase("reset")){
System.reset();
return 0;
} else {
return -2 ; // command not found
// SAMPLING FUNCTIONS
void samplingCbISR() {
// Read from the ADC and store the sample data
vReal[sampleCounter] = analogRead(CHANNEL);
// Complex FFT functions require a coefficient for the imaginary part of the input.
// Since we only have real data, set this coefficient to zero.
vImag[sampleCounter] = 0.0;
// Update sample buffer position and stop after the buffer is filled
sampleCounter += 1;
if (sampleCounter >= FFT_SIZE) {
samplingTimer.end();
digitalWrite(INDICATOR_LED_PIN, HIGH);
void samplingBegin() {
// Reset sample buffer position and start callback at necessary rate.
digitalWrite(INDICATOR_LED_PIN, LOW);
sampleCounter = 0;
samplingTimer.begin(samplingCbISR, 1000000/SAMPLE_RATE_HZ, uSec);
boolean samplingIsDone() {
return sampleCounter >= FFT_SIZE;
and modified ArduinoFFT.cpp:
arduinoFFT::arduinoFFT(void)
{ // Constructor
#warning("This method is deprecated and will be removed on future revisions.")
arduinoFFT::arduinoFFT(double *vReal, double *vImag, uint16_t samples, double samplingFrequency)
{// Constructor
this->_vReal = vReal;
this->_vImag = vImag;
this->_samples = samples;
this->_samplingFrequency = samplingFrequency;
this->_power = Exponent(samples);
arduinoFFT::~arduinoFFT(void)
// Destructor
uint8_t arduinoFFT::Revision(void)
return(FFT_LIB_REV);
void arduinoFFT::Compute(double *vReal, double *vImag, uint16_t samples, uint8_t dir)
Compute(vReal, vImag, samples, Exponent(samples), dir);
void arduinoFFT::Compute(uint8_t dir)
{// Computes in-place complex-to-complex FFT /
// Reverse bits /
uint16_t j = 0;
for (uint16_t i = 0; i < (this->_samples - 1); i++) {
if (i < j) {
Swap(&this->_vReal[i], &this->_vReal[j]);
if(dir==FFT_REVERSE)
Swap(&this->_vImag[i], &this->_vImag[j]);
uint16_t k = (this->_samples >> 1);
while (k <= j) {
j -= k;
k >>= 1;
j += k;
// Compute the FFT /
double c1 = -1.0;
double c2 = 0.0;
uint16_t l2 = 1;
for (uint8_t l = 0; (l < this->_power); l++) {
uint16_t l1 = l2;
l2 <<= 1;
double u1 = 1.0;
double u2 = 0.0;
for (j = 0; j < l1; j++) {
for (uint16_t i = j; i < this->_samples; i += l2) {
uint16_t i1 = i + l1;
double t1 = u1 * this->_vReal[i1] - u2 * this->_vImag[i1];
double t2 = u1 * this->_vImag[i1] + u2 * this->_vReal[i1];
this->_vReal[i1] = this->_vReal[i] - t1;
this->_vImag[i1] = this->_vImag[i] - t2;
this->_vReal[i] += t1;
this->_vImag[i] += t2;
double z = ((u1 * c1) - (u2 * c2));
u2 = ((u1 * c2) + (u2 * c1));
u1 = z;
c2 = sqrt((1.0 - c1) / 2.0);
if (dir == FFT_FORWARD) {
c2 = -c2;
c1 = sqrt((1.0 + c1) / 2.0);
// Scaling for reverse transform /
if (dir != FFT_FORWARD) {
for (uint16_t i = 0; i < this->_samples; i++) {
this->_vReal[i] /= this->_samples;
this->_vImag[i] /= this->_samples;
void arduinoFFT::Compute(double *vReal, double *vImag, uint16_t samples, uint8_t power, uint8_t dir)
{ // Computes in-place complex-to-complex FFT
// Reverse bits
uint16_t j = 0;
for (uint16_t i = 0; i < (samples - 1); i++) {
if (i < j) {
Swap(&vReal[i], &vReal[j]);
Swap(&vImag[i], &vImag[j]);
uint16_t k = (samples >> 1);
while (k <= j) {
j -= k;
k >>= 1;
j += k;
// Compute the FFT
double c1 = -1.0;
double c2 = 0.0;
uint16_t l2 = 1;
for (uint8_t l = 0; (l < power); l++) {
uint16_t l1 = l2;
l2 <<= 1;
double u1 = 1.0;
double u2 = 0.0;
for (uint16_t i = j; i < samples; i += l2) {
double t1 = u1 * vReal[i1] - u2 * vImag[i1];
double t2 = u1 * vImag[i1] + u2 * vReal[i1];
vReal[i1] = vReal[i] - t1;
vImag[i1] = vImag[i] - t2;
vReal[i] += t1;
vImag[i] += t2;
u1 = z;
c2 = -c2;
for (uint16_t i = 0; i < samples; i++) {
vReal[i] /= samples;
vImag[i] /= samples;
void arduinoFFT::ComplexToMagnitude()
{ // vM is half the size of vReal and vImag
this->_vReal[i] = sqrt(sq(this->_vReal[i]) + sq(this->_vImag[i]));
void arduinoFFT::ComplexToMagnitude(double *vReal, double *vImag, uint16_t samples)
vReal[i] = sqrt(sq(vReal[i]) + sq(vImag[i]));
void arduinoFFT::DCRemoval()
// calculate the mean of vData
double mean = 0;
for (uint16_t i = 1; i < ((this->_samples >> 1) + 1); i++)
mean += this->_vReal[i];
mean /= this->_samples;
// Subtract the mean from vData
this->_vReal[i] -= mean;
void arduinoFFT::DCRemoval(double *vData, uint16_t samples)
//#warning("This method is deprecated and will be removed on future revisions.")
double mean = 0;
for (uint16_t i = 1; i < ((samples >> 1) + 1); i++)
mean += vData[i];
mean /= samples;
vData[i] -= mean;
void arduinoFFT::Windowing(uint8_t windowType, uint8_t dir)
{// Weighing factors are computed once before multiple use of FFT
// The weighing function is symetric; half the weighs are recorded
double samplesMinusOne = (double(this->_samples) - 1.0);
for (uint16_t i = 0; i < (this->_samples >> 1); i++) {
double indexMinusOne = double(i);
double ratio = (indexMinusOne / samplesMinusOne);
double weighingFactor = 1.0;
// Compute and record weighting factor
switch (windowType) {
case FFT_WIN_TYP_RECTANGLE: // rectangle (box car)
break;
case FFT_WIN_TYP_HAMMING: // hamming
weighingFactor = 0.54 - (0.46 * cos(twoPi * ratio));
break;
case FFT_WIN_TYP_HANN: // hann
weighingFactor = 0.54 * (1.0 - cos(twoPi * ratio));
break;
case FFT_WIN_TYP_TRIANGLE: // triangle (Bartlett)
weighingFactor = 1.0 - ((2.0 * abs(indexMinusOne - (samplesMinusOne / 2.0))) / samplesMinusOne);
break;
case FFT_WIN_TYP_NUTTALL: // nuttall
weighingFactor = 0.355768 - (0.487396 * (cos(twoPi * ratio))) + (0.144232 * (cos(fourPi * ratio))) - (0.012604 * (cos(sixPi * ratio)));
break;
case FFT_WIN_TYP_BLACKMAN: // blackman
weighingFactor = 0.42323 - (0.49755 * (cos(twoPi * ratio))) + (0.07922 * (cos(fourPi * ratio)));
break;
case FFT_WIN_TYP_BLACKMAN_NUTTALL: // blackman nuttall
weighingFactor = 0.3635819 - (0.4891775 * (cos(twoPi * ratio))) + (0.1365995 * (cos(fourPi * ratio))) - (0.0106411 * (cos(sixPi * ratio)));
break;
case FFT_WIN_TYP_BLACKMAN_HARRIS: // blackman harris
weighingFactor = 0.35875 - (0.48829 * (cos(twoPi * ratio))) + (0.14128 * (cos(fourPi * ratio))) - (0.01168 * (cos(sixPi * ratio)));
break;
case FFT_WIN_TYP_FLT_TOP: // flat top
weighingFactor = 0.2810639 - (0.5208972 * cos(twoPi * ratio)) + (0.1980399 * cos(fourPi * ratio));
break;
case FFT_WIN_TYP_WELCH: // welch
weighingFactor = 1.0 - sq((indexMinusOne - samplesMinusOne / 2.0) / (samplesMinusOne / 2.0));
break;
this->_vReal[i] *= weighingFactor;
this->_vReal[this->_samples - (i + 1)] *= weighingFactor;
else {
this->_vReal[i] /= weighingFactor;
this->_vReal[this->_samples - (i + 1)] /= weighingFactor;
void arduinoFFT::Windowing(double *vData, uint16_t samples, uint8_t windowType, uint8_t dir)
double samplesMinusOne = (double(samples) - 1.0);
for (uint16_t i = 0; i < (samples >> 1); i++) {
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
vData[i] *= weighingFactor;
vData[samples - (i + 1)] *= weighingFactor;
else {
vData[i] /= weighingFactor;
vData[samples - (i + 1)] /= weighingFactor;
double arduinoFFT::MajorPeak()
double maxY = 0;
uint16_t IndexOfMaxY = 0;
//If sampling_frequency = 2 * max_frequency in signal,
//value would be stored at position samples/2
for (uint16_t i = 1; i < ((this->_samples >> 1) + 1); i++) {
if ((this->_vReal[i-1] < this->_vReal[i]) && (this->_vReal[i] > this->_vReal[i+1])) {
if (this->_vReal[i] > maxY) {
maxY = this->_vReal[i];
IndexOfMaxY = i;
double delta = 0.5 * ((this->_vReal[IndexOfMaxY-1] - this->_vReal[IndexOfMaxY+1]) / (this->_vReal[IndexOfMaxY-1] - (2.0 * this->_vReal[IndexOfMaxY]) + this->_vReal[IndexOfMaxY+1]));
double interpolatedX = ((IndexOfMaxY + delta) * this->_samplingFrequency) / (this->_samples-1);
if(IndexOfMaxY==(this->_samples >> 1)) //To improve calculation on edge values
interpolatedX = ((IndexOfMaxY + delta) * this->_samplingFrequency) / (this->_samples);
// returned value: interpolated frequency peak apex
return(interpolatedX);
void arduinoFFT::MajorPeak(double *f, double *v)
double maxY = 0;
if ((this->_vReal[i - 1] < this->_vReal[i]) && (this->_vReal[i] > this->_vReal[i + 1])) {
IndexOfMaxY = i;
double delta = 0.5 * ((this->_vReal[IndexOfMaxY - 1] - this->_vReal[IndexOfMaxY + 1]) / (this->_vReal[IndexOfMaxY - 1] - (2.0 * this->_vReal[IndexOfMaxY]) + this->_vReal[IndexOfMaxY + 1]));
double interpolatedX = ((IndexOfMaxY + delta) * this->_samplingFrequency) / (this->_samples - 1);
if (IndexOfMaxY == (this->_samples >> 1)) //To improve calculation on edge values
*f = interpolatedX;
*v = abs(this->_vReal[IndexOfMaxY - 1] - (2.0 * this->_vReal[IndexOfMaxY]) + this->_vReal[IndexOfMaxY + 1]);
double arduinoFFT::MajorPeak(double *vD, uint16_t samples, double samplingFrequency)
double maxY = 0;
for (uint16_t i = 1; i < ((samples >> 1) + 1); i++) {
if ((vD[i-1] < vD[i]) && (vD[i] > vD[i+1])) {
if (vD[i] > maxY) {
maxY = vD[i];
IndexOfMaxY = i;
double delta = 0.5 * ((vD[IndexOfMaxY-1] - vD[IndexOfMaxY+1]) / (vD[IndexOfMaxY-1] - (2.0 * vD[IndexOfMaxY]) + vD[IndexOfMaxY+1]));
double interpolatedX = ((IndexOfMaxY + delta) * samplingFrequency) / (samples-1);
if(IndexOfMaxY==(samples >> 1)) //To improve calculation on edge values
interpolatedX = ((IndexOfMaxY + delta) * samplingFrequency) / (samples);
void arduinoFFT::MajorPeak(double *vD, uint16_t samples, double samplingFrequency, double *f, double *v)
double maxY = 0;
if ((vD[i - 1] < vD[i]) && (vD[i] > vD[i + 1])) {
if (vD[i] > maxY) {
maxY = vD[i];
IndexOfMaxY = i;
double delta = 0.5 * ((vD[IndexOfMaxY - 1] - vD[IndexOfMaxY + 1]) / (vD[IndexOfMaxY - 1] - (2.0 * vD[IndexOfMaxY]) + vD[IndexOfMaxY + 1]));
double interpolatedX = ((IndexOfMaxY + delta) * samplingFrequency) / (samples - 1);
//double popo =
if (IndexOfMaxY == (samples >> 1)) //To improve calculation on edge values
*f = interpolatedX;
*v = abs(vD[IndexOfMaxY - 1] - (2.0 * vD[IndexOfMaxY]) + vD[IndexOfMaxY + 1]);
uint8_t arduinoFFT::Exponent(uint16_t value)
#warning("This method will not be accessible on future revisions.")
// Calculates the base 2 logarithm of a value
uint8_t result = 0;
while (((value >> result) & 1) != 1) result++;
return(result);
// Private functions
void arduinoFFT::Swap(double *x, double *y)
double temp = *x;
*x = *y;
*y = temp;
and modified ArduinoFFT.h:
#ifndef arduinoFFT_h /* Prevent loading library twice */
#define arduinoFFT_h
#include <stdlib.h>
#include <stdio.h>
#ifdef __AVR__
#include <avr/io.h>
#endif
#include <math.h>
//#include "defs.h"
//#include "types.h"
//#endif
#define FFT_LIB_REV 0x14
/* Custom constants */
#define FFT_FORWARD 0x01
#define FFT_REVERSE 0x00
/* Windowing type */
#define FFT_WIN_TYP_RECTANGLE 0x00 /* rectangle (Box car) */
#define FFT_WIN_TYP_HAMMING 0x01 /* hamming */
#define FFT_WIN_TYP_HANN 0x02 /* hann */
#define FFT_WIN_TYP_TRIANGLE 0x03 /* triangle (Bartlett) */
#define FFT_WIN_TYP_NUTTALL 0x04 /* nuttall */
#define FFT_WIN_TYP_BLACKMAN 0x05 /* blackman */
#define FFT_WIN_TYP_BLACKMAN_NUTTALL 0x06 /* blackman nuttall */
#define FFT_WIN_TYP_BLACKMAN_HARRIS 0x07 /* blackman harris*/
#define FFT_WIN_TYP_FLT_TOP 0x08 /* flat top */
#define FFT_WIN_TYP_WELCH 0x09 /* welch */
/*Mathematial constants*/
#define twoPi 6.28318531
#define fourPi 12.56637061
#define sixPi 18.84955593
#define sq(x) ((x)*(x))
class arduinoFFT {
public:
/* Constructor */
arduinoFFT(void);
arduinoFFT(double *vReal, double *vImag, uint16_t samples, double samplingFrequency);
/* Destructor */
~arduinoFFT(void);
/* Functions */
uint8_t Revision(void);
uint8_t Exponent(uint16_t value);
void ComplexToMagnitude(double *vReal, double *vImag, uint16_t samples);
void Compute(double *vReal, double *vImag, uint16_t samples, uint8_t dir);
void Compute(double *vReal, double *vImag, uint16_t samples, uint8_t power, uint8_t dir);
void DCRemoval(double *vData, uint16_t samples);
double MajorPeak(double *vD, uint16_t samples, double samplingFrequency);
void Windowing(double *vData, uint16_t samples, uint8_t windowType, uint8_t dir);
void ComplexToMagnitude();
void Compute(uint8_t dir);
void DCRemoval();
double MajorPeak();
void Windowing(uint8_t windowType, uint8_t dir);
void MajorPeak(double *f, double *v);
void MajorPeak(double *vD, uint16_t samples, double samplingFrequency, double *f, double *v);
private:
/* Variables */
uint16_t _samples;
double _samplingFrequency;
double *_vReal;
double *_vImag;
uint8_t _power;
/* Functions */
void Swap(double *x, double *y);
#endif
http://www.ti.com/lit/ds/symlink/na555.pdf
