Since the new Particle Mesh chips are compatible with Feather, can we somehow program current Feather’s like the Huzzah ESP8266 WiFi with Particles IDE? Thanks
While the Gen3 devices will be compatible with existing Feather Wings, they use different processors, and as such a different firmware stack. With that in mind, I’m afraid you can’t use the Particle IDE for other devices, unless you port the firmware over and come to an agreement with Particle.
