Failure installing Tinker on Argon
I tried using Tinker to test a small test unit but have been unable to install tinker on an Argon
I initially tried using the Particle app under IOS13. The Aron flashed magenta and after a short period restarted. It just sat there breathing cyan and the Particle App just kept circling around for ever.
I then tried Particle doctor with the Argon in DFU mode - it failed with the following
The Doctor didn’t complete successfully. Error writing firmware: file does not exist and no known app found.
VError: Error writing firmware: file does not exist and no known app found.
at Promise.resolve.then.then.then.then.then.catch.err (C:\Users\Bruce\AppData\Local\particle\node_modules\particle-cli\dist\cmd\flash.js:206:13)
at
at process._tickCallback (internal/process/next_tick.js:189:7)
caused by: Error: file does not exist and no known app found.
at Promise.resolve.then.then.then (C:\Users\Bruce\AppData\Local\particle\node_modules\particle-cli\dist\cmd\flash.js:116:17)
at
I have searched the board but have been unable to find any clues. I would appresicate advice as to the cause and remedy.
thanks
on Looking at the Users/…/particle directory I find there is no /node_modules folder. Not sure how.where this is created - everything has been working fine up until now
