I just received the new batch and trying to claim the device. The device is online breathing Cyan.
curl https://api.particle.io/v1/devices -d access_token=xxxxxxxxx -d id=310046000B4734343XXXXXXX
“ok”: false,
“errors”: [
but did not show up on my device list Console.
After login, particle device add 310046000B4734343XXXXXXX
Failed to claim device, server said: [object Object]
Claim it trough Tinker app, success. However I unclaimed it from dashboard and re-claim it through both 1 and 2 methods above still causes error.
Great question. I believe the reason this isn’t working is due to using capital letters in the device id, i.e. your examples specify B, where as it should be lowercase b. Try lower-casing the device id, I bet that will get you up and running.
@jgoggins, thanks. You are right. I have java script to go through the SoftAp setup but for some reason I keep getting upper case letter in device id.
Is that safe to assume Particle device id string does not include any upper case letter??? If so I will just convert my device id to lower case for now.
