External GPS Antenna
Hi All,
I’m using some Asset Tracker v2 units with Electrons, and have been finding that I definitely need an external antenna. Can anyone point me to a suitable unit? Using the devices in Australia if that info helps.
Cheers,
Aleo
If you are interested in using an active external antenna there are many models available.
At Adafruit, you can get this antenna and this adapter.
At SparkFun this antenna and this adapter.
At Amazon this antenna and this adapter.
But the u.FL to SMA adapter and active GPS antenna are pretty standard, so you can certainly get them closer to your home.
