Error While flashing code
When I try to compile and flash any code to my Particle Boron, it gives this error:
Cannot find module 'core-js/library/fn/object/assign'
Require stack:
- C:\Users\Burak-as-user\AppData\Local\particle\node_modules\particle-cli\node_modules\babel-runtime\core-js\object\assign.js
- C:\Users\Burak-as-user\AppData\Local\particle\node_modules\particle-cli\node_modules\particle-api-js\lib\Particle.js
- C:\Users\Burak-as-user\AppData\Local\particle\node_modules\particle-cli\src\cmd\api.js
- C:\Users\Burak-as-user\AppData\Local\particle\node_modules\particle-cli\src\cmd\flash.js
- C:\Users\Burak-as-user\AppData\Local\particle\node_modules\particle-cli\src\cli\flash.js
- C:\Users\Burak-as-user\AppData\Local\particle\node_modules\particle-cli\src\cli\index.js
- C:\Users\Burak-as-user\AppData\Local\particle\node_modules\particle-cli\src\app\cli.js
- C:\Users\Burak-as-user\AppData\Local\particle\node_modules\particle-cli\src\index.js
- C:\Users\Burak-as-user\AppData\Local\particle\[eval]
make[1]: *** [C:\Users\Burak-as-user\.particle\toolchains\buildscripts\1.15.0\Makefile:167: flash-app] Error 1
make: *** [C:\Users\Burak-as-user\.particle\toolchains\buildscripts\1.15.0\Makefile:111: flash-user] Error 2
*  The terminal process "C:\Users\Burak-as-user\.particle\toolchains\buildtools\1.1.1\bin\bash.exe '-c', 'make -f 'C:\Users\Burak-as-user\.particle\toolchains\buildscripts\1.15.0\Makefile' flash-user -s'" terminated with exit code: 2.
This is very new; it was working before but not now. I am using Particle Workbench on Windows 10. I also reinstalled the extension, and that changed nothing. I am at a complete loss. Please help!
So I ran this command and it worked for me (I was able to compile and flash code to the boron on Workbench successfully):
particle update-cli
For others that come across this issue you can try the same or if yours didn't work, you can view this site.
I also re-installed Particle Workbench from this guide.
Hope this helps!!
